S
sven
First U have to remove the door card.
After removing the door card, lower the window down and remove the seal (circled red). The seal is the problem.
1: heat up the seal end plastic whit a lighter (dont burn it), and press it together
This makes the seal ends grip the door once again, so it doesent move around
2: bend the seals lip in the direction of the arrow a couple of times and then clean it
3: get a hot glue gun and pour the glue between the plastic ant the lip
4: let it cool down, and again put on the door of the car
Now the window will stop to rattle.
Hope it helps
sven
Hope it helps
sven
