Thank you for your comment. Do you know where the split was exactly ? Can you provide a picture with the exact location ? I replaced many components in the EVAP system including the most expensive one like the EVAP Canister and also the purge valve, Also verified with the smoke machine the entire system but could not find any leak whatsoever. Check engine light sometimes goes off by itself during colder weather and I am assuming it's just because there is not much pressure building in the EVAP. Any further help is really appreciatedHi
@rrrsma had similar..
It was a minor split in the EVAP system
Click on their username to read more
I'm going to look for the rrrsma post, thanks.Hi
Oh wow.... this has me worried to say the least.Thank you for your comment. Do you know where the split was exactly ? Can you provide a picture with the exact location ? I replaced many components in the EVAP system including the most expensive one like the EVAP Canister and also the purge valve, Also verified with the smoke machine the entire system but could not find any leak whatsoever. Check engine light sometimes goes off by itself during colder weather and I am assuming it's just because there is not much pressure building in the EVAP. Any further help is really appreciated
Is your check engine light still on? Was it ever on??
If all you have is a permanent code that does not mean anything is wrong with your car. Permanent codes in 2010 and newer cars can be ignored. They do not mean anything IS wrong with your car. They mean something WAS wrong with your car.
Not if you cannot get it to 'stay gone'
If it clears for a minute..then returns
It wants investigating
Always a chance your OBD kit is not communicating properly I suppose..
Yeah CEL was on, I cleared it, off so far.Is your check engine light still on? Was it ever on??
I didnt do any repairs other than change the gas cap out. So far, the CEL is off after I cleared the code with my BAFX bluetooth scan tool.On cars 2010 and newer You cannot clear permanent codes with a scanner or battery disconnect. So they are not "Popping back up" they are just never leaving. That they are present does not mean you have a fault. Means you HAD a fault and the codes are there just to verify that the fix has done correctly. "Permanent" is a bad name for them as it confuses and scares people. A better name would have been 'Verification" codes.
Now you are completely correct if it is a "pending" or "Confirmed " code that pops up right away yea that still needs a fix.
But if all OP is seeing is a Permanent code. Stop throwing money at it because there is nothing wrong.
The EVAP monitor is from the onboard computers a.k.a the CEL? Or is it something else I use to check? Thanks...So all you have to wait for now is your EVAP monitor to run (it may have already, you know how to check those?).
Light is still on. Sometimes when it's colder outside it takes a bit longer for the check engine light to come back on but eventually it turns back on showing the same code.Is your check engine light still on? Was it ever on??
