- Joined
- Aug 4, 2010
- Messages
- 176
- Points
- 161
I am trying to narrow down what could be up with my Punto gearbox before I go spending any money on any bearings.
Its a 1997 Mk1 5 speed manual. Its done 140k. It was secondhand to replaced my old box that had lost reverse gear so we swapped them and fitted a new clutch kit.
The symptoms of the 2nd hand gearbox are as follows;-
Whines in all the gears under part or full throttle (cruising/accelerating)
The noise stops as soon as you back off the throttle.
No clutch problems. No release bearing noises. No selection problems. No jumpoing out of any gears. It works fine but its just the noise that is irritating especially on a long motorway run (keep any suggestions of turning up the radio to yourself, please). Fresh oil in there.
My view is that the differential is fine - if the car continued to whine when in gear but off the gas, this would point to diff bearings - is that correct?
That said should I just have all the bearings replaced including the diff?
Just wondering also what peoples experiences are of gearboxes after a rebuild - are they ever right again - can you realistically refurb a gearbox to give a nice quiet drive?
