Hello All ,
Please bear with me on this I want to pass on as much info as possable.
My wife has a Punto '04 1.2 8v Active, we had the clutch replace a year ago by Mr Clutch Crawley (never again!)
Recently it has developed a noise while on tick over and driving in 1st and 2nd. I thought it was a trust bearing as when you depress the clutch it almost goes. I have been told it is an output shaft bearing.
My wife has also experienced clutch slip from what SHE has described, but I have not been able to get it to slip?
I have a few questions...
I also found out the car is only worth £900 i could buy another one (well almost).
I have found a guide to do the input shaft bearing which covers most of the work and printed it off I be having a look to see if I can do it.
I have done work on cars before so not a complete novice but never removed and engine gearbox, just driveshafts and wheel bearings.
Thank you for getting this far and any advice would be most greatful.
Regards
Richard
- Does it sound like thrust, input shaft or output shaft bearing?
- Can you remove the gearbox from the car with the engine in situ?
- Anyone in the Gatwick area avalible for adivce if I do attempt to fix?
Regards
Richard
