Technical  Gearbox issue ?
Chris RWatts
Well only had the car a week and this morning on my way to work ive noticed that now when pulling off in 1st the gear lever moves backwards by quite a distance.
Also when going from 1st to second it doesnt feel the same as any other gear change.
Anyone experienced this ? If so what was it and what did you do ?
I struggle to put mine into 2nd gear, sometimes im having to fight with it, other times if i just cant get it in i slip into 3rd instead! Im interested to know whats up with mine while your on the subject
A gearbox mount would not cause this because the cables attach directly to the gearbox.. so the move with the gearbox.
To the OP: does this happen only in 1st ? or also in 3rd 5th?
i would say it's a cable issue or the bushing at the end of the cable on the gearbox side.
Yup mine is the m32 gearbox. I knew before i bought it they were a bit of an issue but sods law its gone wrong already !
Okay do done a bit of research and come to the conclusion its most likely the cables or a bearing. Live in derby and have no trust in any local garages ! Any recomendations close by !?
If you need the bearings doing on the m32 gearbox, I'm from Derby too and went to Halifax, there is a specialist on the m32 gearbox, cost me 550 quid and they did it in about 4 hours. If you need any info then pm me and il send you details but I do highly recommend as they was brilliant.
Well contacted the dealership i bought it from and he is going to take the car in an send it off to a specialist to have a new bearing kit fitted free of charge so all is well ! Be stuck in my old gp 1.4 for a week or so now though :(
A bit of movement is normal but keep watching it and see how bad it gets. Turn everything off and see if you have a whinning noise in any gear as you may have the same issue :( also see if you get a slight grinding noisr in neutral when stationary. Hope you have none of the above !
Finally got mine back ! Whole new bearing kit fitted. Box feels alot nicer now. Snake pass on sunday !!
