General Gear shift reverse lifter part number
marky9074
Ashford, Kent
The gear shift reverse lifter trim on our 1.2 lounge has a lot of chrome removed (due to rings presumably). Can this part be replaced? If so what is the P/N?
I believe removal of the gear knob almost certainly will result in it needing replacing, so have seen those leather ones that are on a Cult reasonably cheap. Not sure if this comes with the lifter as it does state it comes with a gaitor.
Just to follow up on this, changed out today. Managed to get the Lounge golf ball style gear knob loose with a rubber strap wrench, then slid a thin plastic trim tool up and around until I could remove it with no damage.
That said, I did change the gaiter for a leather one, and the gear knob also. The reverse lifter trim supplied by typecastboy and subsequent help was much appreciated.
