Hi all,
I have an ongoing and now worsening issue with selecting gears in my 1.2l panda. In seemingly random situations, I'll be met with firm resistance when trying to select a gear. The "fix" is to move back into neutral and then try to find the gear again, at which point the transmission pulls the stick into place smoothly.
I had always experienced this a little with 5th when I purchased it 2 years ago, and then when I started to notice it on other gears assumed that I was not moving the stick itself as directionally as I thought. The resistance can occur moving between any gear, including 3-4 and 4-3. There's no grinding or crunching when it eventually does fall into place, and the gear stays in place until I try to move it again at which point it comes out smoothly.
When it does happen, double clutching doesn't make any difference either. I've now realised it also sometimes happens when the engine is off.
From what I'm reading, it could be as bad as needing a new gearbox if the gears or synchros are damaged. I changed the gearbox oil in March, it came out clear, and am considering draining the oil again to see if there is synchro or gear debris this time as it seems to have worsened.
However I'm hopeful that it could be something slightly more simple than gearbox failure, perhaps changing one of the cylinders as the clutch does become noisy when the car has been driven a while with lots of gear changes, or even a linkages issue.
I would love to know if any of you have any ideas, whether it's self diagnostics I can run before taking to the garage or if there's a fix I might be able to do myself.
Thank you!
Thank you!
- Year
- 2008
- Mileage
- 57000
