Just an update - service will give me 200 Eur back. That's enough to buy all needed tools and material for doing head rebuild by myself. For now I'll only check if ticking will get worse. If not than OK. If yes, I'll do it
Needed tools:
- new head gasket + bolts
- timing locking tools (crankshaft/camshaft)
- valve springs compression tool
- clearance gauges
- torque wrench
- little bit of silicone under valve cover gasket
- brushing paste + suction hand tool (in case if grinding of valve seats needed)
- brake cleaner fluid
- tool for honing cylinders (if needed)
- tool for measuring flat surface
- sandpapers
- torx bit for VVT variator cap
Is there anything else mandatory for head refurbishment?
Needed tools:
- clearance gauges
- torque wrench
- sandpapers
