Hi all,
Got a 2006 GP , 1.4 liter engine (type 199/350) and it uses A LOT of engine oil. (about 0,5 liter every 300-500 km), let me give you a run down of what I already tried:
- Head gasket replacement
- Timing belt + waterpump replacement
- Servicebelt replacement
- Thermostat replaced
- head has been machined to flat and valves were replaced, machine shop did a vacuumtest which was good.
- Isolated a small leakage in the valve cover, so I resealed it with a new gasket and loctite fluid gasket
- Compression test , all cylinders between 190-200 PSI
- Wet compression test doesn't change the numbers on the dry compression test
- Suspect is Cyl.2 as the sparkplug when pulled has a good quantity of oil on it. spark plugs of Cyl 1+3+4 are dry and do not show excessive wear, heat or that the gas/air mix is lean or excessive.
- 2nd suspect is oil loss via the valvecover exhaust, visibly the EGR valve is catching oil but not to a quantity to explain the severe loss of oil, air filter and box are clean and dry
- no visible leaks anywhere, no drips, so looks like a 100% burning oil issue
- no blue or black smoke emitting from the exhaust
I sometimes get P0300 or P0302 errors , for the sake of argument I replaced the phaser solenoid. Errors come back , sometimes.
Just to be sure I checked the ingnition coilpack multiple time, and all 4 ports do not measure over 0,6 ohms, which leads me to believe the coilpack is good.
Recommended oiltype is 5W30, since I'm in a warm climate I switched to an oil with more viscosity, currently using 15W40, but doesn't make a difference.
My thoughts:
- Could be an oil pistonring in Cyl 2 , but tests do not confirm
- Could be bad valvestems , but the head was serviced (bad job maybe?)
- Head gasket, maybe sucking oil into the combustion chamber(s) but again tests do not confirm
I can't put my finger on the problem, thusfar the only thing I really am sure about is that I'm burning a lot of oil, I'm not losing it via an exterior leak.
Tests are not helping me to diagnose.
Anyone could point me in the right direction? Would be highly appreciated.
My thoughts:
