Technical Fusebox diagram/list
Niall_G
Established member
Northamptonshire
Guys,
A friend of mine has a 57 plate Citroen Relay van. I assume its just a badge engineered Fiat Ducato.
Unfortunately it came with no handbook. He's currently running on one headlight as he is unable to find the offside dip headlight fuse (if there is one). There is no diagram on the back of the fusebox lid (the fuse box down by the drivers right knee).
Does anyone here have a fusebox diagram or list that he could use to identify the fuses please?
Thanks.
HTML:
I've been totally confused by this very English "**" plate system. It means nothing to the rest of the world in identifying your van year. I just had a brain waved and googled it, all was revealed. Surely it would be easier to just say an 07 van or whatever year it might be.
Have I got the right type? Hope this helps.
  • FIAT DUCATO X250 Power Supply & Headlamps.pdf
Hi
You could also download the PDF X250 Ducato owners manual, should be the same as the Citroen Relay for that year from the downloads section of the F.F. (link at top of Ducato index page) https://www.fiatforum.com/downloads.php?do=cat&id=23 - there are X250 versions of the Radio/CD manuals & any others he might need if he has no manuals at all.
Cheers (y)
Thanks so much for the quick replies. I'm sure I'll find what he needs. You guys have probably saved his bacon (ie. he's a courier and wouldn't be able to work if he didn't get this info).
Thanks again.
