Technical  Full list of engine codes
Kent
It would be really handy to have a full list of engine codes including the specific variations. Twin EGR, Adblue etc.
Does anyone have one that they would be willing to share?
Hello,
Too many of them to list, too many variations (engines, EGRs, DPFs, EURs, years).
If you are patient, check this thread:
Attached is a csv file renamed as a .txt You will need to import into a spreadsheet to make sence of it. This is just one sheet of a multisheet spreadsheet i use. The code is in column B description C further up is my imputs from various sources as to the solution. Column A is source of info from e-Learn to FF to various old lists even one in Italian. As it is a compilation you may well see several repeats of the same code and different descriptions for same code.
  • ducato OBD fault codes.txt
Thanks for this, but rather than fault codes, it's engine codes and specs I was looking for. e.g. F1AE3481D
