Technical  Fuse location
Thedecorator
Sussex
Hi all, I have a 2014 Fiat Doblo cargo 1.3 multijet.
Both reversing lights have failed, bulbs change, still not working. My next check is the fuse however my handbook doesn’t really specify the location (that I can see anyway).
From whatnindo
I Understand it’s likely to be in the dashboard set of fuses but does anyone have any idea which number??…. If it’s not the fuse then I’ll try the reverse switch on the gear box
Model
Year
2014
Mileage
103000
From whatnindo
I was going to walk up the road and check my 2010 Doblo 1.6MJ, same model shape as yours, but if your handbook doesn't show it then pointless, I assume nothing written on fuse box cover?
Other than that easiest thing would be to bridge the two terminals in the plug at switch in the gearbox with ignition on.:)
Thanks I might try this. The reversing switch was my next point of call, is it easy to access ??
