I fitted a new Lambda last week and want to reset LTFT and STFT values. i seem to remember that last time i checked, my values were around 30% compensation
Somewhere I have read that it could be done with "clear engine faults". I found that option in scanmaster. Deckchair5 had some posts including these resettings.
i didnt clean the Lambda as it was intermittently shorting to ground so didnt see much point... Its done 93,000 so as i understand it the 'average life' of a Lambda is around 100,000
I also have FES but don't seem to remember if the clear faults is possible to do when there are no trouble codes showing at all.
With my ELM I got several programs as ScanMaster, Scantool and more. Often I use FES and Scanmaster, while scantool makes some problems for installation.
You could give it a try.
