Technical  Fuel pump relay
matthewcb
Does anybody know where the fuel pump relay is for a 1999 Fiorino 1.7TD ?
My van broke down and I was told it’s the fuel pump relay. The engine just cut out without warning and a wire was then put from the battery to the actual fuel pump and it runs no problem
thank you
thank you
Hi
Have a look in the forum downloads section
Should be links to the owners manual
If you struggle ask in the TECH section..
As more 'hands on' people will look in there
FIORINO was always a bit niche.. and UNO is OLD now.. so not much going on there either :-(
Hi
Hello
I have had a look in the downloads section but I can’t find anything
where is the tech section? I can’t find it
Hello
Hi
Click on fiat forum icon
That takes you to FF homepage
Scroll down to Miscellaneous
TechTalk is in there
In all probability the Relay will be in the Under bonnet fusebox..
But hopefully somebody will have pics and experience :)
