AndrewRL
Season's greetings to all!
So Luigi has decided to be a Scrooge and not start. By process of elimination (sparks at the plugs, no fuel coming out of the pump, no blockages in fuel pipes, filter seems OK) I have deduced a problem with the pump (let me know if logic wrong
Having removed the pump I was hoping to dismantle it and check it over but it seems totally sealed with no obvious nuts/bolts on the cover unlike those in Haynes and the workshop manual. I know pumps aren't that expensive so may just replace it.
However, before I do that I was wondering if there was any way to check the pushrod. I assume that the engine turning should push this in/out. So I have held my finger on the end of the exposed pushrod and turned the engine via the bolts on the timing cover (or whatever it is called!) as I do to get the timing mark aligned) but can feel no movement. Is this a valid test or is there some other test? I am concerned that the starting issue is not the fuel pump itself but the rod disconnected somewhere.
As always suggestions (in idiots language) gratefully received.
Many thanks!
Many thanks!
