Technical Fuel leak
Technical Fuel leak
Kiltedboarder
Evening all
Just finished fitting new coil, electronic ignition, overhauled the carb, set plugs, did timing
Car started 1st time and I did the dynamic timing. All running sweet
But this evening went into the garage and string smell of fuel
Took a look and all round the top of the engine down from the carb was wet with petrol
I checked and fuel pipe is tight, carb it tight etc
After my earlier work I did check and no fuel leaks and had car running for a good 15 mins
Seems leak had occurred during standstill
Any thoughts
Yeah checked everything, all solid and tight. I took the carb off this morning and the bowl is full of fuel if that adds any info
I think maybe my new float was a bit off so readjusted it and let’s see, 1 more question for the choke housing - with the choke off shout the pin inside the carb be actuated - so up or in the down postion?
