Hi
I’m new to this forum and also to Fiat. I have owned some Alfa Romeos in the past and a lot of other brands but never a Fiat.
I have recently acquired a 1998/04 Barchetta. The fuel pump runs continuously on ignition and I can hear a loud swooshing noise in the rail. I have checked fuel pressure and it’s steady at 3 bar and but fuel pump will not cut off. The pressure valve in the rail is not leaking and no vacuum leaks anywhere.
Weirdly, if I leave the ignition on for a couple of seconds, the car won’t start, no spark. If I turn the ignition off and then turn to crank without stopping at ignition on, the car will start and sputter a bit until it settles on idle after 3 seconds.
My main problem is what seems to be misfires, small hiccups on idle but more violent jerking around 2000 rpm and light throttle. Car also feels a bit down on power.
I have changed the spark plugs - old ones were identical to each other and looked really good colorwise - and checked all connectors to all sensors. Exhaust is not smelly and no smoking.
No fault codes in ECU ( connector in passenger footwell) and no warning lights. Tried unplugging maf, idle control valve, throttle positioning sensors etc. Only negative impact. Checked Lambda which seems to alternate between closed and open loop as it should. Good live readings from all sensors.
I’m suspecting the big relay 7767970 on the firewall since fuel pump runs continuously on ignition but it seems impossible to find a new relay. Is there another OE number to use or will any other car brand OE work as a replacement?
Best wishes from Sweden
- Model
- Barchetta
- Year
- 1998
- Mileage
- 130000
