Technical  Fuel cut off unavailable and check engine light blinking
talal
Egypt
Hi home
My tipo 2021 was crashed, I did the steps to reactivate the car after crash and it started ok, but the radiator wasn't installed then turn it of and installed the radiator and tried to start the car again but failed to do,
there was no cranking and fuel cut off unavailable message appears, also the check engine light is blinking there was some codes after scanning the car
1 - U040F fire prevention system fps status from body control module invalid serial data received
Also has a code on BCM as follow
1-B1081-86 ECM ( engine control module) fps ( fire protection system ) failure ( (invalid signal )
2- B10AA - 4A check configuration failed - incorrect component installed
3- B1080 -86 ORC ( occupant restraint control ) FPS ( fire protection strategy ) failure signal invalid
Thanks for your advice
One of the computers in the car knows it has been in a crash so it won't let you start the car , to prevent a potential fire.
