My day is not going well
After coming to a stand still on the water pump change i turned my attention to the clutch cable.
I had a new one from a previous Sei and thought i would double check the length with the one in this car.
Started to remove the mounting bolts from the bulk head only to get a turn and the bolt sheared .
Thought erm i might be able just to get away with holding by the 1 bolt..... And you guessed it also sheared :bang:.
Now i assume someone has had this happen in the past, and drilling out probably is the only solution.
But its very tight in there, so whats the best way to sort it?.
Cheers.
2001 MPI SPORTING.
Cheers.
2001 MPI SPORTING.
