sackedminer1
- Joined
- May 26, 2013
- Messages
- 1
- Points
- 1
hi can anyone help with problem of wiper blades catching each other
Anyone got any pics? I haven't got any dots I don't think as the screen has been replaced![]()
I tried taking a pic, but it's very difficult to see them. Have a look at yours from the inside out, you might see the passenger side dots that way. Unless you really don't have them.![]()
I don't even have a window for the Chasis number![]()
Now you can see them from the inside. As you'll see, my wiper is a tad higher than said dots. Hmmm, best put that right then.
Ahh very useful, how do you adjust the park position?
Run your wipers on a wet screen, turn them off, lift the covers at the base if the wiper, undo the thirteen mm but, gently pry it off the spline, line it up to the dots and tighten the 13 mm nut back up. Don't over tighten though.
Hope that helps.
Phil
Hope that helps.
Phil
Have you had a replacement screen then? If so, it must be a bad copy.
shouldn't need to run wipers at all, leave at park possition, remove arm and replace on spline in correct location surley?
As per post 7, I thought I was the only speed reader![]()
I suggested running on a wet screen is to make sure they have gone as far down as they should. Only my thoughts.
Phil
