C Chris Woodward New member Joined May 18, 2012 Messages 14 Points 5 Jun 4, 2012 #1 Drivers side head light fiat stilo is buzzing on main beam and pointing in the air . Any ideas .
G Grant4132 New member Joined May 20, 2012 Messages 35 Points 12 Location Netherfield Jun 4, 2012 #2 Mine is doing that too going to try and disconnect the motor. What car is yours mine is a stilo abarth.
OP OP C Chris Woodward New member Joined May 18, 2012 Messages 14 Points 5 Jun 5, 2012 #3 Stilo dynamic 1.8 doing me nut in , can you just take the just take motor off , or do you have to remove the light .
G Grant4132 New member Joined May 20, 2012 Messages 35 Points 12 Location Netherfield Jun 5, 2012 #4 Think I might have to take the light out not alot of room I'm my stlio abarth engine bay but if I can I will just disconnect it
Most Easterly Pandas Speed Reader of the Year! Parked in the garage Written a guide Joined Aug 15, 2007 Messages 44,236 Points 8,079 Location Norwich, Norfolk Jun 5, 2012 #5 The motor ideally needs replacing. For now you can remove the rear cover on the headlight unit and disconnect the motor by pulling the wiring to it out (it un-plugs) Jon.
OP OP C Chris Woodward New member Joined May 18, 2012 Messages 14 Points 5 Jun 5, 2012 #6 Most Easterly Pandas said: The motor ideally needs replacing. For now you can remove the rear cover on the headlight unit and disconnect the motor by pulling the wiring to it out (it un-plugs) Jon. Click to expand... top man cheers !
OP OP C Chris Woodward New member Joined May 18, 2012 Messages 14 Points 5 Jun 5, 2012 #7 Top man cheers !
