I had to do the front brakes and discs yesterday.
All fairly sraight forward, though I wasted a lot of time trying to figure out how that top guide pin is removed. It didn't help it was caked in crap at the back, and felt like an allen headed bolt. 8mm was too loose, but did catch, though not brave enough to try if it was that loose. 10mm was way too big. Same with torx, T50 was loose, T55 was way too big.
I'm guessing it's a 9mm allen key??? Of course nowhere sells those.
How does that top guide pin come out?
Anyway, I was able to get it all done just leaving that guide bolt attached to the carrier. Normally like the carrier off to give a good clean with a wire brush on the pad guides, but managed in situ.
Seems a bad design with that guide pin at the bottom, it's very exposed to road dirt. It had stuck on the passenger's side and one pad was down to the metal, though they were all very low.
I should really have checked the new parts first. I spent time cleaning up the bottom pin, and care taking out the disc bolts (made of super soft metal), only to find new bolts in with the discs and new pins in with the pads!
