Hello
Since i had a new engine fitted i've had the yellow warning triangle with the ! flickering. I had this before with my last engine too. I suspect maybe it could be low oil pressure. However the manual says that the red oil can will light up with the fault message. I get no fault messages with the flickering triangle though. Also my battery is failing and i do need a new one, could this be linked? Am i worrying about nothing or should i get the oil pressure checked?
The car is a JTD. It sometimes starts flickering when the key is in the MAR position.
Just to add: the manual says this triangle could be low oil pressure sensor. Sorry i'm getting confused. Maybe theres a sensor failure somewhere.
Phil
Phil
