new2fiat
Good news - the flat spot has been fixed!!!
The dealers knew about the EGR problem already without me having to say anything, but after some further investigation (and thankfully having been able to feel it for themselves on a test drive :worship they did this:
"Basically we have fitted a restriction to the egr system, which reduces the cross sectional area available for the exhaust gas to pass through into the inlet manifold. This restriction acts like a venturi and speeds up the gas passing through it, so making it mix better with the inlet air and also clean the egr valve itself. It does not reduce the exhaust gas passing through it as we have checked this using airflow meter readings. This is available for most egr systems on Fiat 1.9 and 2.4 diesel engines.
Service news 10.21.08 includes a test procedure to follow before fitting the restriction."
Hope this makes sense to anyone with a similar problem - and that it helps you too! It's another niggly problem with the car fixed :slayer:
