Fire Exit
Fire Exit
Mrs. Dave
keeping an eye on you...
Does anyone know about building or fire regulationsin a workplace? if so can a fire exit door at the front of a building be changed to a customers entrance/exit door? if so, how do you go about doing it?
doubt it.
there are all sorts of problem regarding, fire exits, and emergancy exits.
they are different things apparently, and both can't be the same door (i.e emergancy doors have to 'latch open', and fire doors and fire exits have to 'latch closed').
Helz said:
I know they can because a branch of our company did that recently, but I think it involved planning permission, not sure on the regs required to do it.
So do you mean, they changed what was just a fire exit door to a customer entrance/exit? does this door have a window in it?
Yup, exactly as you say. Not sure if it had a window in before as I didn't visit before it was done, but it does now. The shop used to have just a front entrance but now also has a small side one closer to the surgery next door. As I say I know it went through planners but I wasn't involved so don't know the specifics.
The fire officer visited my place of work last week, to carry out an audit, as there are new fire regulations for the work place.
In my place of work we would not be able to change the position of a fire exit without agreement from the fire department, and if agreed I would then have to review the fire risk assessment accordingly, and change the building plans.
Contact the fire department, they will advise you further. :)
I would ask the Local Fire Dept in your area.
Where I work all exit doors have a 'Push Bar to Open' bar on them. We can lock people out but cannot lock people in.
I would presume that if you converted the fire door into a normal door that another fire door would have to go in its place AND as long as there are clearly labeled exits allowing public to escape in any direction incase of an emergency there would be no problem.
We want to make it into both a fire exit door and a customers entrance/exit door, let me explain we have a warehouse (workplace) with one fire exit door at the back and one at the front,(so we have the legal requirment) and 2-3 feet next to the front fire exit door (to the right) is a shutter big enought to get a luton van through it, so as Helz says it is possible without having to put in another Fire exit door, I am going to get professional (sp) advise about this but it is just an idea at the moment.
I'm not the person to authorise but as long as it can't lock people in and has a "Push Bar To Open" which is clearly indicated and signs poiting towards it as a possible exit then it should not be a problem.
The Main Doors at the front of where I work are like this and have glass panes on them.
