cptcuddles
- Joined
- Oct 20, 2012
- Messages
- 34
- Points
- 9
Firstly thanks for all the advice to my other posts.
Car lasted all of two days before throwing a P0170 light and drinking fuel. Was intending to sell in a couple of weeks anyway as wife as e new car arriving, but have decided as tax as run out to park up and sell.
Drove lovely then parked at work and from moment it started for return journey I could tell was running rich. Got home and long term trim was showing 99.9% hence the fault code. As I hate having to admit I'm beaten I've cleaned all air ducts and cleaned and reseated and set the throttle body and its now better, was wondering if any of the following readings look odd as they are from immediate cold startup after resetting ECU the longterm before starting showed +99%.
Short term trim -100%
Longterm trim -99%
Pre cat lambda 0.52V -100% short term trim
Post cat lambda 0.05 0.00% short term trim
Air pressure 13.3in/Hg
Closed Loop
Ignition advance 3.5 degrees
Coolant 100F
798rpm
After about 5mins of idling the short term trim had settled to swinging between 20% either way and the long term to -40%. Took the car for a brief run and the lambda settings were swinging all over the place when the car went into open loop which as was accelerating and decelarating I guess is normal but the P0170 code was now showing as a pending code and the car had gone sluggish again
Although I've promised wife I won't spend any more time looking at the car I just can't resist it. Going to check vacuum leaks next. Sorry for length of post
Longterm trim -99%
Closed Loop
Coolant 100F
798rpm
