- Joined
- Apr 8, 2004
- Messages
- 25,219
- Points
- 3,671
You'd have to set-up some live parameters to monitor, connect it up and go out for a drive re-produce the problem and look at the data.
I just brought this cable, made an offer of £21.00 and it was accepted.
Seller has over 50 sold and no bad feedback about them.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150451337633
Bought the cable from someone on here and it didnt come with a CD no.
Anyone with flashing odometer or retrofitted Connect Nav who wants to test the Proxi Alignment procedure?
Hello Yani,
afaik the Proxy Alignment Procedure will not stop the flashing odometer with a retrofitted Connect Nav - only a time delay circuit will solve this problem.
The Proxy Alignment only sends the ORIGINAL configuration file from the bodycomputer to original nodes that were replaced or which lost their configuration and need to be realigned again (i.e. a replaced instrument cluster ,steering column , climate control panel or door node.)
After the Proxi config. the Connect Nav will still be a foreign and unknown node found during the 4 sec. check , hence the mileage will blink without using a delay circuit.
If the rest of the Proxy Alignment procedure works that would be a very good piece of work you've done !!
Does this mean I could re-program a replacement remote key to work on my Stilo. My current key has stopped working (remote locking).
hi all,
I've read about this FiatEcuScan program and it sounds great and want to give it a try.
Can anyone tell me what kind of cable I need for my Bravo TD75 SX?
Thanks a lot
