Technical FiatEcuScan diagnostic software
I'm from Slovenia and i have Fiatecuscan, becuse i need it, to do a proxy procedure to stop blink km(distance) on my dials (retrofit a Connect Nav+ unit). So i did it again (proxy procedure) becuse i replaced my menual climate control unit in my Stilo with automatic, and the distance on dials are stil(again(n)) bilinking.
Any ideas what to do?
Denis
the proxy procedure seems to be unreliable for the climate control node.
If you are capable of reading the eeprom contents of the 9(s)12 microprocessor inside the bodycomputer (i.e. with UPA) it is possible to alter the configuration file to add the climate control unit.
If you post your binary file here i can change it for you, after that you can reprogram your BC with this file and your BC will accept your climate control because it's configuration matches the present nodes.
You also might try the 4 sec. delay circuit between the power line towards the climate control node to keep it invisible during the initial check by the body computer.
But first of all try the 2.8 version of FES, according to Yani the Proxy procedure should be improved.....
No... you can access everything except airbags with an ELM327 cable and interface. You can access airbags with a cheap VAG-COM cable.
So just to confirm, patching pin 3 to pin 7 with my ELM327 won't allow access to airbags and I need a different cable?
Why is everyone saying you just need to connect pin 3 to pin 7 :confused:
I've brought the license and this software is amazing, does everything except the airbags with the patches I've done, so this is because I've got the wrong lead for the airbag ecu through the OBD port then?
Jon.
@Denis,
Can you please tell me how did you change your manual a/c to auto and what parts do i need?
thanks
hi! pls can someone tell me what connector i need for my 53-reg stilo 1.9 jtd, just downloaded the fiatecuscan software
