Technical  fiat tipo electric problem
zairis
please i need your advice , i am facing electrical problem with Fiat tipo ,it doesn' t start and the battery is always low ,while the alternator Works ,
.i believe their is a short circuit problem somewhwere .
any suggestions how to solve it ?
i think if i take out all the fuses and then put them all back again one by one untill i found the reasons .
any advice is welcome and i appruciate it.
thank you in advance!
It depends which model you have, but if yours has an analog clock, it could be causing the battery to lose charge.
I know it sounds unlikely, but my 91 Tipo 1.4 had just that problem about a year ago, and has been fine since I disconnected it.
The other obvious reason is that the battery could be dying.
thank you for your answer sir !
the model is Fiat tipo 1992, 1400cc i.e
maybe is that ,but how can i disconnect the clock.
and what about the fuses may i disconnect them and put them back again one by one untill i find where the problem is ?
How long does it take for the battery to go flat?
Has the battery been tested?
The clock is easy to disconnect if it's analog like the one below.
