Technical Fiat strada 1.2 fuse box
Strada1979
South Africa
Good day
Attached picture of my 2007 Fiat Strada 1.2 EL fuse box i side the cabin
I see according to the owners manual what all the blade fuses are for ....
I need to know what the 4 relays next to the fuses are for...also i see there are spaces for relays that is not there🤔
Any takers?
Ta
Johan
No problem
I have another issue with starting the car...
I took out the fuel pump thinking it was faulty but ended up being a faulty relay
Any way....pit everything back together and now it starts...sputters and dies....
Double checked everything but still jave the problem
I am thinking of setting fire to it or push it down a cliff🤣
Any advise on this?
Greetings
Johan
No problem
Any advise on this?
Greetings
Johan
What else did you disturb..?
Does it restart instantly.. Or really struggle?
Nothing else i touched
It starts but the rpm is really really low...id say 300-400rpm
Idles for like 2-3 seconds and dies
Then it wont start at all for a few minutes
I checked the fuel pressure on the fuel rail and that seems fine.
I am beginning to think of fuel starvation....its not getting fuel...like i said pump works relay is fine
Will the return line fitting that i fixed not have anything to do with this? Say if its obstructed or blocked maybe?
Another question...if the battery voltage is below 12v will that also affect the pressure of the pump?
Unlikely
If it has power to crank motor is should be fine.. 😉
Next test, turn key at MAR.. how long does the tank pump run?
Should be 5 to 10 seconds.. 🙂
Try running it twice, then crank.. Does motor run longer?
Unlikely
Hi there
Fuel pump runs 5-10 seconds...
I have tried the MAR thing but still nothing
