Technical Fiat Stilo SUNROOF Motor (How to connect it with DC12V power supply?)
borhan0089
Hello friends,
Does anyone know how to connect Fiat Stilo sunroof's motor directly with DC12V Power Supply?
Which pins must be used for full open and full close (((((Turning right and Turning left))))
I want to test it in my house. Therefore I need to know how to connect it with a separate power supply in my house.
I uploaded photos..
Thanks in advance.
Hello friends,
I uploaded photos..
Thanks in advance.
Hi looks a lot like the Croma motor. It's not a simple unit, Do you want to power it to test it or to use it for something else?
You can download the electronic service manual from the downoad section
https://www.fiatforum.com/downloads.php?do=download&downloadid=345
This has the wiring diagram and other info including faultfinding guide.
HTH,
Robert G8RPI.
Thank you friend..
I did not find in Fiat Stilo elearn what I want.
Simply I need which pin is +12, -12, rotating left, rotating right,
Thank you friend..
It's not that simple. The "Motor" has an electronic control unit built in so needs the correct signals not just power. It even has a digital (CAN) interface. If you suspect it is faulty it would be easier to just get a used one from a scrap yard / car breaker.
Robert G8RPI.
Please quickly.. I am fixing Stilo's SUNROOF..
Hello,
I am fixing now my Fiat Stilo SUNROOF.
I need to use the motor in my home to fix and try the Sunroof . The motor works great. But how to wire it with DC12V? Which Pins? to rotate it right and left?
I saw many people did that on YouTube but I don't know how.
Please help me as soon as possible.
I uploaded photos.
I am waiting.
Do you have a link to a youtube video of someone testing a Stilo (or similar 12 pin Fiat) sunroof motor?
Really I don't have all tle link right now because I saw many videos . And I didn't see which motor they used. But of course It was Fiat Stilo.
Can you advise me how to do it or use another motor maybe?
I am waiting
This is one link on YouTube
[ame]https://youtu.be/q7gWmU6fBiE[/ame]
Re: Please quickly.. I am fixing Stilo's SUNROOF..
Just use the mechanical wrench in it you can insert 5mm bit in to it and turn it it'll be better and safer than electric .
It is broken now.
It worked only few minutes. Because it is not very easy to move the rails
So it is very important to use a motor
Whats broken the wrench ? Then use a 5mm bit from your toolbox
To power the motor youll have to disassemble it i think cause its not just a dc motor it has a pcb controle plate with it
Ok stop u need to connect negative to pin nr2 and plus to pin no 10 to fully open or pin no 1 to close
These are the pins inside the motor.
with numbers...
So are sure? ??
I found it.
The best way now. haha
Whether the voltage can be connected to the connector as said and that it works as it says: "u need to connect negative to pin nr2 and plus to pin no 10 to fully open or pin no 1 to close"?
