hi
i have a scudo with the following faults on lexia, please could i have some input/ idea of what you think the problems could be
i also have faults with the central locking not working and the multifunction display which resets language back to factory and clock flashing 0:00 (which should just be that the permanent 12volts is missing)
so far i've done this before i got lexia (just used a basic scanner)
tried getting egr valve off but someone rounded one of the bolt heads:bang:
changed fuel filter and air filter
before i forget, the turbo was broken when i got it and the oil return hose was missing, oil feed was blocked in the turbo, luckily as i drove 70miles back home
i fitted new turbo and oil return hose, check oil flow from oil feed which was ok, run engine, took it for a spin with no change to power ( not got round to doing oil change or fitting new oil pickup yet)
result of faults were done with engine running at idle
P0118 : coolant temperature signal
Characterisation : Short-circuit to positive or circuit open
Status : intermittent .
Variables associated with the fault
Engine speed : 0000 rpm
fuel temperature : 017 °C
output injected : 000 mg/stroke
Status of engine : starter motor circuit
P0104 : Flowmeter signal
Characterisation : Open circuit or short circuit to positive or to earth of the sensor supply or of the signal
air flow per cylinder : 0000 mg/stroke
Inlet air temperature : 155 °C
Turbo pressure. : 0988 mBar
P1462 : Electric EGR valve position copy signal
Characterisation : drift of the movement of the valve or programming not carried out
Status : Permanent fault
Inlet air temperature : 007 °C
engine coolant temperature : 036 °C
EGR valve relative position : 000 %
EGR valve status : 0765 mV
battery voltage : 12.65 V
P1351 : Preheating relay circuit
Characterisation : Relay supplied and Plugs never supplied
Engine speed : 0771 rpm
battery voltage : 12.55 V
pre-heat relay control : unspecified value
preheating relay status : Active
P0113 : inlet air temperature sensor signal (flowmeter)
Characterisation : Short circuit to positive or open circuit or value too high
engine coolant temperature : 003 °C
Inlet air temperature : 152 °C
P0299 : Turbo pressure electrovalve control
Characterisation : Flow too low
Engine speed : 2185 rpm
Turbo pressure. : 1024 mBar
turbo pressure reference value : 1871 mBar
Turbo electrovalve OCR : Value invalid %
output injected : 025 mg/stroke
P0405 : Electric EGR valve position copy signal
Characterisation : signal voltage too low
engine coolant temperature : 033 °C
EGR valve status : 0000 mV
EGR valve position : Value invalid %
P1728 : CAN communications
Characterisation : torque information not valid
vehicle speed : 000 kph
engine torque : 000 Nm
gross engine torque : Value invalid Nm
gear ratio : Neutral engaged
P2143 : Electric EGR valve control
Characterisation : open circuit valve closed
P0087 : Fuel high pressure regulation
Characterisation : Pressure below reference
Engine speed : 1157 rpm
diesel presure : 0165 bar
Diesel limited pressure : 0557 bar
pump output : 10345.10 mm3/second
diesel flow regulator voltage : 1882 mV
