Styling Fiat punto04 5door bodykits
Hello. first time here .
anyways i have a fiat punto facelifted version 5door and it has a bodykit.. but i got into a car accident today and ill have to replace front and back bumpers..
anyways i found same bodykit all over the internet but with one problem.. everyside says the back bumper is only for 3 door.. ye i have 100% the same on my 5 door and cant find any other than that 3door version.. so im rlly confused .. do the 3 door ones rlly wont fit? how did the privious owner got these one for 5door.
cant post links so ill name the bodykit.. : maxton,ntc
S-Tuning - Fiat Punto Mk3 BMB Body Kit<- name on one page.. every seller has differant..
this is the bodykit i have on my car.. i think the sideskirts r diff but not rlly sure.. but the front and back ones r same.. yet 5 door.. the back on my car seems totally fine.. doesnt seem like anyone modified it for 3 door bumper..
so does anyone know if i can fit the 3 door version or not? and if there r any 5 door bumpers(can be other style).. i searched but cant find anything.. t
ty!
Get some pictures up
The arse on a 3dr is different to a 5dr
The rear lights, rear bumper and boot and wiper setups are different shaped
Yet towbars are identical? Weird huh?
The rear bumper do interchange between mk2 5dr and mk2b 5dr
But you cant say do a mk2 3dr to a mk2b 5dr... different shape
Post piks of your current damaged one up
Ziggu
Yeah i read everywhere that they r differant but i dont see it.. Look the same to me. Still waird that my 5door i rocking a bumper only 3door can.. What i the acuall dofferance? What would i need to change of i buy the 3door to fit the 5door.. Cuz i checked evrrything and there like max 3 back bumpers for 5door and noone as good as this one for my taste... Ill post pics of my back one later one when i wake up..
Still can i get some suggestions for bodykits or seperte body parts do mk2 facelifted.
here is the pic of the bumper. do you need differant angles?..anyways my is a 5door and has this on it.. so what mods would i have to do to fit another 3 door onto my 5 door again. cuz clearly its posible
That aint a mk2 or mk2b bumper at all.... not availible in the UK
Thats totally after market.... as for the 3dr an 5dr are different lines
Ziggu
what u mean? yeah its aftermarker ofc, i said im looking for bodykits
websides sell the one posted below but its 3 door.. so how do i get the one i have?
Doesn't look to badly damaged why not just get it repaired? A new bumper will need painting and prepping so no money saved there
thats true the back isnt that dmged. but i thought fiberglass cant be fixed? how to fix this than? ill have to wait till thuseday to talk to mechanic to see what the insurence offered and how he will fix it.. but i thought ill have to buy new ones
front bumper dmg.. some cluster dmg on the right side and some on the left but its still covered by the line..
As said 3 door bumper dont fit 5 door theres a massive gap between bumper and rear panel if you try:D
looking at your bumpers they look easily repairable with a matting kit and a grinder
try a bodyshop rather than a mechanic
be aware xmember behind front bonnet may be bent
see if spare wheel comes out in boot and boot floor under wheel not up
in uk that would be written off
your tailgate looks slightly twisted too at the passenger side (left hand drive?)
this colour paint is hard to match and apply as it has metal flakes in it, make sure painter is good because its hard to blend otherwise and leaves a strange mark that shows through the lacquer
good luck
ps a good fiberglass man should be able to cut a bit out of your damaged rear bumper and blend it into a new rear one to get it to fit i would guess
front bumpers just fit if you get the right one for your car ie 2004 to 2006
good luck
ty for the info.so my rear bumper was modified for the 5door than? since its the same as the 3door one shown on pic and there is no 5door option awailable anywhere.
mechanic will check if anything is bent behind the bumpers. not sure about the back yet but the metal part behind front bumper is bent as i already noticed.. also front lights are all ****ed up and bonnet is also slightly curved up. that is easly fixed and not a problem the mechanic will get that done. the only problem i have is with the aftermarket bumpers as i dont know how the insurence will decide.. they can aprove fixing in which case i dont care ill just leave the car at the mechanic and hell do all the fixing without any care from my side about money.. but if the insurence mark car dmg as totaled (since the car is old.. lot of milage and the dmg is high because of the aftermarket stuff) i might get a rlly low money offer from the insurence and ill have to work around that.. thats my worst nightmare..
edit: the tailgates r fine, just waird angle pic. or maybe they were like that all the time. :D didnt rlly notice
also the problem is that idk if there is any bodyshops around my country.... but if there is the mechanic shauld know.. anyways ill talk back on thuseday when i hear from the insurence and my mechanic
the front xmembers are welded in and take an age to cut out with an air chisel
you may need to look for one of these as they arent available from my bodyshop supplier anymore due to the age of these vehicles
the slam part (ie upper part that bolts in)should go back into shape with a slide hammer
the headlights usually just break on the clips and these days i use a hot staple weld gun,most bodyshops have these now and are a great tool and can now be bought off ebay and delivered from china from about $30
ty but its not a DIY project for me :D wasnt my foult for the crash so the mechanic will do all the work.the insurence will defenetly acept the chasee fixing. the bumpers r in doubt.
