Technical fiat punto smoking and missing after new head gasket
Thanks chaps for advice, will take plugs out tomorrow. Reason for assuming rings as problem is that I know the head is 100% as just been refurbished as earlier in thread. Will post results.
OK so I took the plugs out before I did anything and in picture left to right cylinders 1-4... number 3 looks black and oily :(...
thought id do the dry / wet compression test anyways and results are:
Dry: 1=212, 2=195, 3=205, 4=210 (all PSI)
5ml of oil: 1=225, 2=220, 3=217, 4=245
not sure if these results are good or bad as I don't know what I should be expecting to get compression wise from it?
I have also uploaded video of the smoking exhaust: http://youtu.be/BvdESBtNbiw
and this of the engine once warmed up to see if anything is 'chuffing' out of the rocker cover, I don't think there is.
http://youtu.be/yvSdFBfBDMk
Any more ideas chaps, what do you think of the compression test results?
looking at everything there it would appear you have the same issues i had with a punto last year
your compression rings are good but your oil control rings are shot
on taking the pistons out of my engine the oil control rings fell in pieces
you could always re ring the engine of course
the one i had i suspect it broke the rings because there was too much oil in the sump
How difficult is it to change rings on one of these? is it not easier just to switch the engine? Although heart breaking to have spent so much on the head to get it A1!
head off
sump off
remove pistons and rods from top of block
replace rings
hone if needed or a quick wet n dry
i scrapped mine and fitted another donkey because parts of the ring were found in the sump
So its decision time... Abandon the refurbished head and dump a second hand engine in there (means finding one, picking up or getting delivered then hoping its a straight swap and it works properly, then swapping ancillaries, getting shot of old engine) or get some new rings and swap them.....
I'm guessing that the head is refurbished, if I do the rings hopefully nothing else too major could go wrong in the engine or am I being a bit naïve? :rolleyes:
I guess other stuff could still go wrong?
whats the vote on this, anyone done rings on one of these before?
May start strip down for replacing rings tomorrow, hopefully it's head off / sump off then undo big ends and pop pistons out the top... I hope!!! Will post pics as I go might assist others on 'how not to' lol.
Well the time has come, found some free time and I have removed the engine from the Punto and it was surprisingly easy, did it on my own!
Engine is stripped and pistons etc out...
Have checked and the oil control rings are all gunked up on 1 & 3 so definitely the issue.
ImageUploadedByFIAT Forum1398967969.897935.jpgImageUploadedByFIAT Forum1398967993.169853.jpg
First one is number 3 second one is number 4 the oil rings all clogged with gunk on number 3 and number 1 not far behind it either...
The bores are un scored and all else looks in good order so this weekend I will be de glazing the cylinder bores, replacing the rings, head gasket head bolts (again)! Timing belt & tensioner, water pump, thermostat, bottom engine mount, oil, filter antifreeze etc.
Will be taking loads of pics in case anyone is interested!
Yes I was reading a technical manual and it says no need to replace head bolts but I have already got some so may as well put em in...
So far I have deglazed cylinders:
Changed rings (broke 1 set and swore a lot) and yes price is £19 per set
ImageUploadedByFIAT Forum1399151090.454937.jpgImageUploadedByFIAT Forum1399151116.932268.jpg
Before and after cylinder 1
Reinstalled and torqued big ends
Cleaned sump and refitted
ImageUploadedByFIAT Forum1399151303.453322.jpgImageUploadedByFIAT Forum1399151323.843225.jpg
New clutch de greased and fitted using my patented alignment tool
ImageUploadedByFIAT Forum1399151377.682456.jpgImageUploadedByFIAT Forum1399151393.495779.jpgImageUploadedByFIAT Forum1399151410.582969.jpg
Loaded back into car
ImageUploadedByFIAT Forum1399151456.797771.jpgImageUploadedByFIAT Forum1399151472.234355.jpgImageUploadedByFIAT Forum1399151529.910387.jpgImageUploadedByFIAT Forum1399151547.333320.jpgImageUploadedByFIAT Forum1399151588.551781.jpg
Starter motor fitted
Started to fit alternator but knackered, to be continued!
So alternator on, new timing belt & tensioner supplied were wrong ones so I had to reuse old ones for now:ImageUploadedByFIAT Forum1399224423.271915.jpgImageUploadedByFIAT Forum1399224447.589575.jpg
Timed up TDC in bottom pulley
Head gasket fitted then the headImageUploadedByFIAT Forum1399224550.445239.jpgImageUploadedByFIAT Forum1399224563.213011.jpgImageUploadedByFIAT Forum1399224581.485064.jpgImageUploadedByFIAT Forum1399224597.898840.jpg
New thermostat fitted
ImageUploadedByFIAT Forum1399224628.520237.jpgImageUploadedByFIAT Forum1399224842.426223.jpgImageUploadedByFIAT Forum1399224861.021369.jpg
Connect pipes and plugs
ImageUploadedByFIAT Forum1399224946.363595.jpgImageUploadedByFIAT Forum1399224981.309885.jpgImageUploadedByFIAT Forum1399224999.229745.jpgImageUploadedByFIAT Forum1399225045.422047.jpg
TDC on cam shaft
Engine mount & rocker cover on
Oil and water and connect charged battery and start the sucker up...
NO SMOKE!!!
Now for the next problem, whilst refitting the alternator I noticed it didn't rotate freely so thought maybe a dry bearing as it rotated freely 3/4 of a turn then seemed to go tight then was free again on each spin. Thought maybe a little 3 in 1 oil on the bearings may help but couldn't separate the alternator so I just dripped some in each end then span it which seemed to do the trick...
The problem is now when the car is started from cold it's fine, battery light goes off and all good after about 2 mins the battery light comes on and the power steering stops working and steering gets really heavy. voltage at battery with engine running is 11.9V... Does this mean my alternator is fubar?
Yes.
