www.towingcapacity.co.uk
Your V5C should show the maximum permitted mass for a trailer; regardless of your towing experience, exceeding this could lead you into nasty legal complications in the event of an incident.Towing experts recommend a maximum of 85% of cars weight on tow. You need considerable towing experience to exceed this ratio, and must NEVER exceed the cars weight.
The max weight can also be calculated from Vin plate, under the carpet in the bootMy 500 shows 400kg unbraked/800kg braked. but the important numbers are the ones that apply to your specific car - there have been numerous changes to these weights over the car's production run.
Yes I absolutely agree. You will get fined VERY heavily if you are caught overloaded. 30 years ago my father stupidly put 1 ton on the back of his work 1 ton pickup. Then, it cost him £300 and his firn £1200 in fines.Your V5C should show the maximum permitted mass for a trailer; regardless of your towing experience, exceeding this could lead you into nasty legal complications in the event of an incident.
Nose weight, suitability of towbar, lighting/numberplate requirements all need to be complied with, but the maximum towing weight shown on the V5C is the definitive limiting factor which you can't legally exceed. If stopped for a roadside check, I'd expect that data would be available to the police in real time from your car's registration number.
I have found that exactly as you say you can mananage with this limit and the Panda is immensley stable when towing. The diesels hae pretty well the same chassis and are rated higher at 900kgs which is plenty for a small caravan.Since Panda's and 500's are very short behind the rearaxle, the influence is not as big as Dave thinks. Approximately 50 Kg's works perfect. At least for me...
gr J
Yes, we have one and, after time, the foam insulation deteriorates…it’s double sided and sticks to the glassfibre body and also holds up the fabric trim.A small freedom caravan can definitely be towed by a Panda. I am on the lookout for a good one. The new prices are well more than I think itws worth though. The man I spoke to back in 2019 was in a freedom van, and he rated that as good too. Big issue was low levels of insulation and resulting condensation. This is not insurmountable however.
I believe the small Eribas are also easily towed…I helped drive one off a really muddy festival site about 15/16 years ago, (a bright yellow 1.2 Irish Panda) the owner was laughing her head off as I weaved between the stuck vans and even a few big 4x4s (with stupidly wide low profile tyres). I then did the same with my pink camo iveco daily, it’s secret weapon was a limited slip diffTheres definitely a knack to towing with small cars and accepting the limits is the big one that you need to get over. Once you do this and feel the outfit, working with it rather than fighting it, it all becomes easier. Its good to see Porta confirming the Freedom van tows OK with a Panda.
