Randyryang
- Joined
- Oct 27, 2016
- Messages
- 5
- Points
- 2
First off this engine is actually in an old dayton 10kw propane generator. With that being said, the generator was free from my job and it has been sitting for years with only 38 hours on the engine. So i feel confident that the engine is good shape. The engine is the 1372cc ie that was in the fiat uno. I got the unit home and connected it back up to the propane tank that came with it and i can not get the thing to start no matter what i try it will only back fire through the carb, i have replaced the timing belt because i assumed it was out of time. After researching and finding out that the engine was in the fiat uno, i refered to the timing procedures in the haynes manual and rest the timing with and installed anew timing belt. But still only get backfiring through the carb, when i turn the distributor as im crank in it the backfiring changes frequency somewhat but still never actually starts. I have checked compression on each cylinder and it was good on each. I have replaced the spark plugs also.
