Technical fiat bravo hgt turbo
Any advice on where a can fill the gearbox oil? I've checked out fccuk and they say to fill the gearbox through the gearbox dipstick! Unfortunately the dipstick fouled with my steering rack pipe work! So I blanked it off! Is there anywhere else I can fill the oil?
Also an update, I've got a hybrid Turbo built by FC performance, front mount installed and a SIP from pro alloy fitted. Coming together quite nicely now.
help is much needed! I have a problem with the abs! The abs light is on so I've ran a live data test and all 4 sensors are reading speed which indicates to me they are working! So I ran a diagnostic and 1 fault recorded which just says engine pump! I assume it means abs pump! So I ran a direct feed to the pump and it works fine! So that leads me thinking the fault maybe within the abs control unit not giving power to the pump! Just need someone else's opinion on this or if someone can shed some light!
yeh I did have a look at that guide but that's pretty complicated for me! My abs is the ate model! Or is the lucus the same? Looks like I'll be sending my abs pump to a specialist or even buying a second hand pump!
There is no ATE pump. Lucas on old one, bosch on the new one if I remember correctly.
Opening the box is the hardest part if you know electronics. Most likely a relay or driving fet gone if the control box responds to diagnostics.
Best case screnario is that you can fix it just by taking it on a field and sliding it around braking. Seen that work once as the contacts/valves were sticky from not using the ABS at all on normal driving.
hello from gr,at the time im building a bravo 20v turbo,my question is what i should change or pin out from 20v turbo ecu loom to fit on stock 20v n/a?
