General Fiat Bravo 20v Turbo
So finished the rear frame today
Managed to find some Monroe Multipla rear shocks which are a lot stiffer than the bravo ones
Also finished the rocker cover
Got bored with the standard red and wanted something abit different so it was sprayed in Peugeot metalic blue And lettering polished
Now to pick up this gearbox and put the bugger in :D
By any standards this oil doesn't look healthy
Tbf I'm kinda glad I went
Since picking up the car had nothing but problems with the gearbox, the Speedo stopped working, gear lever became really stiff and the gearbox was seaping oil from one of the joins lol
Oh well the 6spd is of to Quaife tommorow for a rebuild :D and some advice on a new LSD
well they prob know better than me lol. depends on the ratios ultimately which i have no idea about on these.... On the FIRE engines the 6 speed makes all the gears closer so its easier to keep them up in the revs, does make a difference for sure, but flat out the 6 speed is also slower. So on my turbo cento's being that boost came on so low down fitting a 6 speed made no sense and also they just go like the clappers upto the rev limiter in top gear so having one that lowered top speed was just pure sillyness.
Really looking forward to having a passenger ride in this thing one day!
There is a Bulgarian dude on ebay that sells poly sub frame bushes, not that dear..
few companies making after-market normal rubber ones too, its not really gonna be an expensive fix unless you pay someone to do it - just a pretty big job. But an excuse to clean up and paint the subframe ;)
How are the mounting rubbers on your rear subframe? They seem OK, have they been changed?
I'm sure the ones on my Brava are goosed, expecting some aggravation and expense in the near future..
The coupe that the frame came from had it's subframe bushes changed by Joe at FCSS about 6months ago
so they are basically new
Ps I almost cried when I saw the coupe
Right quick update :
Gearbox and clutch have been fitted, and completely transformed the car, also the steering rack has given up so have ordered a replacement
New parts list
6 speed gearbox
Valeo clutch
Starter motor
2x front wheel bearings
Brake pads
2x Reconditioned drive shafts (not the intermediate shaft)
New Visco
