General fiat bravo 2010 poor headlights
angieandsimon
I have a bravo 2.0 sport multijet, the headlights are rubbish.
Candles would be better.
Do any of you know of a conversion or upgrade that is available.
Many thanks.
Simon & Angie
I would get the leveling checked first as it's a quick and cheap job at any MOT place. Because could be too low aimed. And check the automatic adjuster is set to 0 on the screen.
If that's all fine. I know that Xeon lights were an option for the bravo but I've heard they are hard to source second hand. And don't know your budget.
I have fitted HIDs conversion kit on ebay on mine and because the lenses are foggy they produce a great light and doesnt interefer or blind on coming traffic
https://www.ebay.co.uk/itm/55W-HID-...hash=item2389973ea7:m:mDuxVR-N__o0zJjA7FaSc8g
This is the idea the main bulb is H7 and i have never failed an M.O.T with them in either
Guess they haven't checked them very well as they are a mot failure regardless of how well the beam Patten is
Not that many more place's check headlight's beyond the fact they function these day's
Found the same thing when I bought mine. Just put some better bulbs in, then be a knob and raise them slightly so you can see. You'll find you don't actually end up blinding on-coming motorists at all.
Then just lower them again before you take it in for an MOT so it passes. Literally the only way I've found to be able to see at night.
try first with lenses clean and after this put some serious HId Xenon H1 kit, it is simply instalation. I have also this in my plans with my bravo.
I do it in this way because it is easier than opening the headlights. You can clean your lenses inside through the H1 little hole and outside from the same size hole from the left side. ;)
Just a heads up even led are illegal to retrofit into halogen and hid enclosures
Your avarage police officer is unlikely to ticket you for them however but they still arnt road legal for anything but off road use
