Fiat Bravo 1.8hlx Intermittent stalling
K
Keith
I have a Fiat Bravo 1.8hlx. Intermittently on pull away the revs go down to 500 and often the car stalls. I have taken the car into a fiat dealer for a full service and to look at the problem but as yet have not managed to get it fixed. Any ideas???
Misfire/tickover loss
Have a look at the message i posted under Misfire / lambda sensor earlier this month. Disconnect the lambda sensor and see if that fixes fault then you'll know. Is it particularly during the wet?
Tickover problems ?
the only thing that ever goes wrong with the 1.8 is the idle control valve on top of the throtle housing the next time it gives you this problem just give it a light tap and see if it starts to work if it does replace it
I
1
6K
stevew
S
M
6K
mick gibbons
M
J
577
Jamie Rose
J
