Technical Fiat Albea not start
kartul678
Hello, i need help to find a problem my 2008 Fiat Albea 1.4 57kw.
In the cold mornings car start and shut down. I tried many times but not starting.
Okey, i call a friend who come with diagnostic equipment and find that intake air temp is 70C, but outside temp is 5C.
When i unplug the intake map sensor the car start and i can drive but its not correct to drive when the plug is not connected.
I ordered a new Intake MAP sensor (0 261 230 030).
Yesterday my friend came and put it in the place, all faults deleted and trying to start, but same result, start and shut down..
New sensor shows correct outside temp and when i unplug the new sensor and start the car and put the plug back the car stops when plug connected.
Car coolant temp sensor working, maybe someone can help me :)
Thanks.
I put some pictures.
Welcome to Fiat Forum.
Maybe introduce yourself first, before asking questions...;)
Btw, this is better ask in the "Tech Talk" section above...
Thanks for reply.
Maybe you can put this thread in the Tech Talk section?
did you or your friend maybe pull the wires out of the plug it self at any point, this sounds like either the plug is the wrong way around or the wires got pulled out and put back into the plug the wrong way around...that's just my opinion I had the same problem on my opel (Vauxhall) a while back found that the pref owner changed wires in the airflow meter
kartul678 :)
No, we dont take out the wires.
Car has only one owner and this problem comes 2-3 weeks ago.
I forget to watch absolute pressure, maybe the pressure side is faulty new sensor? Temp side working.
I think i need to buy another new sensor and try my luck :)
