Malnisbett
- Joined
- Jun 19, 2021
- Messages
- 12
- Points
- 56
Just acquired a 2014 Fiat Abarth 500 with a selespeed gear issue. Car had a stored code P2917 although it goes into gear and drives fine. However when changing down manually from 5 it goes straight to 2nd but don't know if this is normal or not?
The main issue is when end of line calibration is completed, it leaves an error message saying "plausibility error during engage 5th gear"
Checked the fluid, that's all fine, completed clutch bleed etc.
Now working out what to do next? Is it likely to be something physical like the actual clutch or Clutch slave cylinder or something else? Strange that each time it says 5th gear
I've resolved issues on the normal Fiat 500 by just changing a clutch and on the 500l by replacing the concentric slave cylinder but never come across this error during end of line calibration.
