Technical TFT Abarth skin not working MultiEcuScan
2013Abarth500
Poland
Hello I installed a tft cluster in my 2013 Abarth 500 and I can’t get the Abarth screen after doing the proxy alignment even tho I changed byte 65 from 00 to 60 I get a 500 sport screen and not the Abarth before coding and changing the odometer it was an Abarth theme. I don’t know what to do anymore did it multiple times and still 500 sport. Anyone knows how to fix that?
only thing I can think of is it maybe came from a 2016 or later which used U-connect when 2015 and earlier used Blue-and-Me. It might have a bearing, I don't know.
It’s with blue and me system it even shows the logo when turning on I have all the options to select in menu like previously
Thank you I will try that . someone also said that’s because the EPROM code is the shorter version and in order for it to work you need to write the missing EPROM. I have no idea how to do that
See if anyone near you with MES can try for you? As long as you are saving the new code I can't think of any reason why it is ignoring you!
Try using control + C in MES proxy, and adding bytes up to 197. Alternatively, have a look in the MES forum.
Update: The added bytes are "00" and then when you do the proxi alignment, they or may not get overwritten.
Did you ever found a solution? I'm having the exact issue but with a 2018 fiat abarth cluster.
