General  Fiat 600D Interior Help
Mr 500
Hi All,
Ive been looking for a Fiat 500 although ended up with a 600D RHD that i couldnt go past. So dont let the username fool you!
Ive got a few questions:
1) My 600 is missing sunvisors. Are 500 and 600 the same size/shape?
2) Any one know what all the switches and lights on the dash are/do?
3) The previous owner installed seat belts in the front (3points) although at the top of the b piller there are two holes. Ive been told that a braket originally was there with a strap so the people in the rear could get in and out. Does anyone have some pics of the bracket and strap?
thanks
Sam
I've also just bought a Fiat 600. I have a LHD but for me it's:
There's 2 things sticking out behind the steering wheel. The short one is the side indicator and the long one is high beam/ low beam. On the dashboard the left switch is the lights, the right one are the windscreen wipers. The top one I haven't figured out yet:).
Sunvisors I don't know, I had a 500 and they looked the same but I'm not 100% sure.
Seatbelts I have no clue. Mine has aftermarket seatbelts.
thanks Bas
do you have the straps on the B pillar?
there is also something above the ignition (where you put the key in) im not sure what it is. It looks like a button or light of some sort although looks like it is broken.
appreciate your help
Sam
There's 3 buttons around the place you put your key in. The left one is the lights, the right one is for the windscreen wipers.
I haven't figured out what the one above the ignition does, nothing happens when i switch it on. Will look into that.
I will check for the straps too.
My car doesn't have these chrome strips on the side (door). Anybody know if this was on all 600's? Mine is a 1971 600 0.8E, is it supposed to have those?
Yes it is present in my car.The right and left door trims for non abarth pre 64 600's.
The switch is the panel/dash lights and no yours doesn't have the mould as it should have normal opening doors ie not suicide
