The battery seems fine on your video but I would always try with your lights off, however that is not your problem. You may have a problem with the cold start device or possibily the crank angle sensor that doesn’t like the extreme temperature. On cranking the injector are open and they will quickly throw fuel into the cylinders and then the. I’m not sure about the compression I can’t hear it clearly it but as some others have Siam it sounds like it’s lacking compression and it’s the multi-air engine there is a possibility that the multi air unit has an air lock. There is a procedure to bleed this but it might be happening because it has the wrong oil. Make sure it has the correct grade oil in the car and take it from there.
