Technical Fiat 500l 1.4 16v
Kevin Allan
South Staffordshire
Hi guys, thank you for accepting me to the Forum.
I have a 2013 Fiat 500L 1.4 16v, 75,000 miles, that I bought cheap as a non-runner. Basically, the engine turns over very well but there is no spark at all four spark plugs and replacement plugs and coil packs have not improved the situation. The compression test seems fine with each cylinder recording circa 14 bar / 200 psi and fuel is being delivered to the injectors.
I did think the ECU could be the problem as an auto-electrician said there was no out put to the coil packs but a replacement that has been cloned to the car has made no difference.
Strangely, the main headlights and climate control don't work with the ECU connected but they come on when the ECU is disconnected. My Multiecuscan has recorded two codes when I scan the engine and BCM which are B0110-15 and P068A-68.
Has anyone seen these before or has knowledge of what they mean..??
Yours hopefully
Kevin Allan, Fiat lover
