Technical Fiat 500 Sport 2008 water in boot and rear footwell finally solved!
LiamC
Water traced to coming in through upper rear corner pillar, ending up in the boot and rear passenger footwell. Thought it was the wiring loom as a dodgy repair had been completed previously. Replaced, still leaked. Next the Arial as a small amount of water was getting through. Replaced, still leaked. Thought it may have still been the wiring loom so sealed the joint with guttering sealant as a test. Still leaked! Water...gravity....i know how it works!....in a last ditch attempt removed the plastic roof rail....turns out slight corrosion on the rear joint hidden by the rail. Temp fixed with guttering sealant.....now dry as a bone! The attached picture is taken looking towards the rear looking at the corroded joint with the roof rail removed.
I have no idea how I got the first picture to rotate! ??*♂️
How do you get those “rails” out? My car has slight corrosion at the very back end where the water runs out down under the rear hatch it be very interested to look underneath & try a bit of prevention
i second this, it would be interesting to know indeed!
The rails are stuck to the roof using some sort of grey compound, there are no fixings as such. I just prised them off very gently from the rear. You end up with some compound on the rail and some on the car, so it doesn't come clean if you like and need to tidy up before sticking back on. Like I said, it was a last resort for me.
Yeah I’ll be doing that then! I can imagine it was very hard to prise them out I worry about bending them trying to release then getting them back in would be harder
Saying that I’m dying to get in there and see what corrosion it’s going on!
A tad warmer today so I prised mine off cleaned the area dyed the plastic strips back black and stuck them back down! A bit of corrosion but mainly paint loss so not too much to worry over
May need doing again one day but not sure what I’d treat the area with!?
