ahmett
Prominent member
Looks like my trouble free period with the Fiat 500 1.4 is coming to an end!
Had issues with misfires x 2 due to faulty injectors so replaced 2 injectors and all 4 spark plugs, so so far so good.
Now today I had an issue with the thernometer going above half towards 4/6 and even 5/6 (weather is super hot at 40c but still), pulled over to investigate.
Coolant was very low, put some water in, but when I did that smoke started coming out the other side of the engine bay and the coolant would fall down again to the minimum level. Also turned off the AC when driving to stop it overheating more and turned it to full heat no AC, but no hot air was coming out.
No leaks that I could see except some fluids in the engine bay, but nothing catastrophic. Saw that the radiator is working, so it can't be that. Was worried about head gasket failure but didn't see any bubbling in the coolant or any mixture of coolant and oil when I checked the oil.
Put some water in and drove it home without the engine going too hot as I was only a 15 min drive away and I guess driving at speed helped keep it in check.
The garage is like 500 meters from my house so it should be fine driving there from cold tomorrow AM, let's see!
The temperature gauge was fluctuating between normal 4/8, 6/8 and 7/8, but I mostly kept it at between 4/8 and 6/8 before stopping and letting it cool down with some water.
Car is at 192,000 kms
