I am going to replace the front suspension legs can anyone tell me how the top of the leg is attached to the body, it appears to have no bolted on attachment to the car.
The front suspension strut isn't bolted to the body at the top. Once the upper top hat bump stop is removed, it just falls out.I am going to replace the front suspension legs can anyone tell me how the top of the leg is attached to the body, it appears to have no bolted on attachment to the car.
Providing the top mount is in good condition, it fits snugly into the wing, and the weight of the car on its wheels prevents significant movement. If there is noticeable movement here with the car standing on the ground, the top mount is excessively worn and should be replaced.Thanks for your reply does this mean that the top of the leg is able to move in use.
The top mounts are handed; it's been known to find them fitted incorrectly.I am wondering if one or both of the legs has been incorrectly fitted
Your issue is tightening the nut you only have a 6mm Allen head to hold the shaft, a Torx or simple flat would be better
Yep, I'd say, you need to press it into the metal top cupDoes this look like the correct front bump stop and cover?
