Technical  fcuk rounded wheel nut
Edinburgh
okay so ive just bought a cinq sporting and ive done a service so i thinks ill just whip off the rear wheels an check the brakes etc so i find that king kongs tightened the wheel nuts!![:(!] so i get them off eventualy including the crappy fiat locking bolts and the brakes are fine so before i pack up the tools i thinks ill just loosen the fronts as well and bless my barnacles if one of the front locking nuts isnt rounded off [?]so guys any tips? i was thinking about hammering on a small(ish) socket and trying that cos i dont fancy drilling it out and then removing the stud failing that any idea on garage costs for this
mmmmmm custard coloured cinq
i must say im totally underwhelmed by the design of the fiat locking nuts luckily i took the other 3 off before messing around with the rounded one cos the keys(i had 2)just rounded of with hardly any torque
update used the socket method and it worked a treat luckily the nut was coppa slipped
Try to make it a flat slot head screw with wheel cutter (i hope it's name for that tool)
Seicento GO!
1.1 MPI
Inox exhaust
try and get some stud extractors? you drill a hole in the rounded off nut, then screw in the extractor<it has a reverse thread on it! then when it tightens right up keep going,because it's a reverse thread its like your trying to take out the wheelnut(anti clockwise)because your going anti clockwise the extractor is going in then when it cant go in any furtherit stops and because your still turning anti clockwise hopefully the wheel nut should start to come out! hope this makes sense???
WHEN THIS BABY HIT'S 88...YOUR GONNA SEE SOME SERIOUS s**t!
If you use stud extractors, make sure the hole you drill is exactly on centre. And wear safety specs, you don't want your eyes in the way when tool steel shatters[xx(]
Was the wife's but its mine now!!
Lowered 40mm: Its a go-kart!!!
